Hello I am trying to offset this surface with the command Offset_Surface (solid option).
I
And this is what happens:
Is there any way to do this as Skin or Thickness commands in MODO ? or any other 3D polygonal soft ?
Thanks a lot
I
Thanks a lot
Can you upload the file? On the forum page click on the vertical arrow in the icon bar above where you type your post.
Hi Bruno - the problem is the splitting of the offset? Try using the Loose option.
Apparently you are right. Thanks a lot.
Unfortunately there is a morph aspect that I am not considering.
This type of bend has a strange outcome with thicknes…If you try it you will see thar the extruded surface makes an awfal twist.
Is not a Rhino problem , is a Geometry problem. I think what I want is not real.
I wanted kind of a clean transition, but I think is not possible cause the surface is going from one plane to another…and that has a downside.
Hi Bruno - if you create a G2 blend between the two planes, and MergeSrf, offsetting will not split up the result, if that is a problem. I’m not sure what you’re after though.
Ribbon_Help_PG.3dm (184.5 KB)
I guess you’ll want to trim the ends of the planar bits where they get distorted.
Pascal thanks so much. I am trying to understand what did you do.
Is the surface in red with the process you mention ?
How did you build it?
