Hi!
I’ve got a question – please find attached a screenshoot.
As you can see, I am trying to do and offset of a polygon, an irregular triangle. Each represents a floor and its to be offsetted continuously by 2 metres more than the lower floor (0,2,4,6…) after the offset command has been run, all the curves are joined into one group. I tried running “list item” but in this specific case it wont work (i have run this command before, with array linear, and it worked - i dont know if the offset command works different?. Any idea what could be done?
In the screenshot you an see I continued with extrude, cap etc. This gave me a wanted result but treating all the curves as a whole. I wanted to further rotate each but this cannot be done, as it is a group.
Thank you!
PS. Two parallel parametres flow because each treats a tower respectively
