Offset segments
Hello!
I’m new to Rhino. I come from knowing the program FormZ and wondering if anyone else is familiar with this program as well. I’m trying to separate a facing of an object so that I can have 2 separate texture map areas. I’ve attached a screenshot of what FormZ calls an offset segment. Wondering if I can do the same in Rhino. Thanks!
HI Alissa -
You can use the SplitFace command to create those two areas. You can then apply different materials to different sub-object faces.
That worked! Thank you so much!
