Can anyone tell me why I can’t offset this polyline curve down 12". When I try and run the offset command from the front view I get lines above and below and some missing.
Hint: you can upload files here directly… Just drag and drop the file into the message window. People don’t necessarily want to deal with going through Dropbox to get a file.
–Mitch
Yep.
As Offset is kind of a planar operation, Rhino doesn’t like to offset 3D curves that much… One workaround is to split the curve at the 90° corners and offset the individual parts using Front and Right views, then re-join.
–Mitch
