Offset Polyline
I’d like to get the offset of this polyline:
When I use the Offset Curve component, the behavior is as expected up to a certain threshold, after which some segments disappear:
And when using the Clipper offset, it always produces a closed curve, which is not what I want:
The desired result would be:
offset_curve.gh (2.9 KB)
Have you tried Offset Curve Loose?
What Rhino version are you using?
Wierd. Seems like a bug. Using today’s update.
In the meantime, here is an imperfect solution using Offset Curve Loose, as Martin suggests:
Why is it “imperfect”?
Because it culls the polyline at the collapse of the first segment, and then real deal would null at the collapse of all.
