Offset open polycurve
I want to get this figure,
from the following polycurve,
The command for get the figure form this polycurve is:
I am developing in c# and RhinnoCommon.
Someone knows how I can get it?
Thanks
Hi Miguel,
You can get the offset curve using the method Curve.Offset() http://4.rhino3d.com/5/rhinocommon/html/M_Rhino_Geometry_Curve_Offset_1.htm
Here is a sample:
This function will give you a offset curve. Then you need to create a PolyCurve with both curves and two lines connecting both start and end points.
Thank you very much Enric.
This is a good idea, in fact I use the following function:
Curve curvasOffset = curva.Offset(Plane.WorldXY, -10, 0.001, CurveOffsetCornerStyle.None)[0];
But, I want to know if there are anyway to do the figure with only one function of rhinocommon.
Thanks again, (Moltes gracies :wink: )
