Hi
I hope someone can help a Newbie
Im doing the rs.AddSrfContourCrvs and need to offset all the curves it creates. How do i do that?
/Astrid
Hi
/Astrid
Have you tried OffsetMultiple
command?
If you want to do this in python take a look at this example:
surface = rs.GetSurfaceObject("Select a surface")[0]
startPt = rs.GetPoint("Start point")
endPt = rs.GetPoint("End point")
curves = rs.AddSrfContourCrvs(surface, [startPt, endPt], 1)
for curve in curves:
rs.OffsetCurve(curve, [0,0,0], 1.0)
Astrid.py (280 Bytes)
thank you very much !
When it does the offset it offsets in different direction. Is that due to the UV direction or something else?
This one let you to select offset side manually:
offsetSide = rs.GetPoint("Offset side")
rs.OffsetCurve(curve, offsetSide, 1.0)
Askj92.py (324 Bytes)
