Dear community, I want to create a 0.01m offset continuous surface from the initial data, however, as the surfaces are not joined, the offset is performed using the normal plane of each face. As a consequence the result shown by GH are a set of surfaces non connected on the edges. Is there a way of solving this problem?
I tried to do what you said but I have the same problem in the borders of the structure. In the edge border of the surface the offset is performed using the normal vector and exists a discontinuity.
The input I uploaded is a file.ghdata, since the surface is created with a tedious code and I wanted to simplify the result for you. It must be loaded in grasshopper using INPUT DATA
Data inputs are interesting solutions to organise better your models, I have used it a lot since I discovered it. Thanks for your interest. The surface is the result of complex of mergeing different section of the structure (I have to divide it in diferent surfaces since I need to have them separated for other questions such as separate walls and vaults and the different sections of the structure( Constructive phases)). That’s the reason when I merge the surface the isolines are different depending on the surface chosen. I am working in meters. Thanks a lot for your help
Here is an example using Python. Because of the underlying surface issues, the result isnt too great, but it might help you get closer to what you are looking for.
Thanks for your effort, it is an advance although there are some issues to solve. I tried the shell component in Pufferfish and I achived almost the same result but not the final shape I was looking for
