What is the Absolute tolerance setting in Document Properties? Try using 0.00001 which is the smallest absolute tolerance which should ever be used. Understanding Tolerances [McNeel Wiki].
A better solution would be to change units to microns and scale the objects. Changing units in Options > Document Properties > Units will ask if the objects should be automatically scaled.
