Does Offset curve have a setting so arcs are extended with arcs. In the attached file I’m getting a short line.
Thanks Mark.
temp.3dm (306.9 KB)
Thanks Mark.
temp.3dm (306.9 KB)
Hi Mark- does setting Corners=Round get what you want?
I don’t believe so.
In this case I would suggest deleting the short line and using Extend which has a by arc option.
@pascal may have a better idea. edit: or maybe not.
Well can it be put down as a request or bug then, I’ve never really understood why you would want to extend arcs with a line anyway.
Mark.
Hi Mark- sorry, I misinterpreted your question- what Brian said…
From my search in the bug tracker, this request is on there from before, sometime, along with a comment from the developer that it is unlikely to happen in V6. I added your ‘vote’…
