OK, now I’m aware of the bad things that can happen, so I will be careful until you guys fix this.
// Rolf
// Rolf
Meantime, the Between Onsap may be helpful.
Rolf, is it possible you did a BooleanDifference here, subtracting the already trimmed vertical jamb from the head jamb? That would result in those split edges.
Hm, forgot that. I think I did Boolean on the vertical jambs, so they got the profile from the upper and lower jamb. The vertical jambs (1600mm) were only extruded from a profile curve.
// Rolf
