unnamed007.gh (20.2 KB)
TRANSVAAL PATTERN 05.3dm (490.3 KB)
I wanted offset a set of lines, often they intersect each other so I used the component ‘offset’ from ‘clipper’ plug-in to have the outline when they intersect. I also wanted give different offset to each lines so I used a ‘gene pool’ and connect it to the input distance to give to each lines a different offset. The result is giving me a series of offset for each distance of offset i put in the gene pool.
Do you know how can i obtaiin just one offset correspondig to the value in the gene pool?
thanks a lot for helping
