I try to move the outlines of my T-Splines surface / brep 5 - 10 cm inwards to extrude them and generate a railing for my surface.
Unfortunately, neither offset nor offset loose does work at all.
I hope you can help me.
Looks very good and also very close to what I’d like to achieve.
Is it also possible to get only the outer contours of the surface as a closed offset instead of each one?
If necessary, I have to remodel the last edges by hand.
Thank you very much!
