Odd Sweep Problem
In the the attached I have a turbine inlet taken off of blueprints.
If I do a sweep I get this horrible monstrosity:
Sweep apparently does not like the flared bell. I could build the bell separately but I was wondering if there is some way to do this all together?
Problem Sweep.zip (17.8 KB)
Hello -no, in fact I’d build this in multiple sections.
To get the best result here, I think you’d actually want to make this from four different surfaces - you have a blend at the bottom which looks to be a blend between two straight sections of cut pipe - so ideally you make those from 3 surfaces, and then the flared portion at the top which absolutely should be its own surface - a revolve will do nicely there.
ETA - yup, what Pascal said
