I am working on getting some reliable absolute max FPS results for Holomark 3, but when I run -TestMaxSpeed with vsync off I get some strange results. I either get 1282.05 FPS or 1612.90 FPS. Nothing in between, and it appears random when I get which. (it takes either 0.06 or 0.08 seconds, why not 0.07?)
I won’t use the command line command to do the test, I just wondered if you guys knows what’s going on.
EDIT: I did a bunch more tests and I also get “0.06 seconds. (1587.30 FPS)” some times.
This on a new machine with an i7 10700 and a RTX 2060 Super, fresh drivers running V7.
