Is there any way to obtain the point data between every curve segment? (the white dot)
Try explode. It’ll give you all vertices.
thanks mate !
You also may have a look at discontinuity ( no duplicate vertices) depending on what you want to do
Also, if it is a polyline you can use the control points component.
