Obscure bug (DisplayMode change in specific condition)
hi @pascal
I think I just found a very obscure bug, not very significant but reporting nevethless:
if only ONE viewport is open (no other views present, 3 out of default 4 closed) AND the viewport is floating, changing the display mode from the RMB+ViewTitle does not work. Works by Display panel and shortcuts, but not the menu.
( just in case you can reproduce it, and strive for Rhino’s perfection ; )
–jarek
Hi Jarek - I can see that, thanks. The entire menu seems to be disconnected - that’s a legit bug!
https://mcneel.myjetbrains.com/youtrack/issue/RH-49997
