Hello, is there a way in Rhino 5 to do an oblique selection?
Or custom selections? (or sub-selections)
I happened to need it in several particular situations while modeling. Thanks
You might look at the _Lasso command for selection. —Mitch
Hello - see
SelBoundary
SelVolumeSphere
SelVolumeBox
SelVolumePipe
SelVolumeObject
Any of that help?
What about _SelBrush?
Thank you all. Perfect solutions. For some reason i always missed that selection commands.
I would like to take this opportunity to ask something else regarding selection. One thing that would help me a lot:
When I do _Unwrap on NURBS i can select edge “loops” faster with the “chain” function.
Is there a way (plugin, script) to do the same with meshes? Something that automatically selects more edges based on specific angle tolerance between the selected edge and the others connected?
Hello - SelChain
set for Tangency but with a high angle tolerance may do what you want.
I dont understand how to use it to select seams while unwrapping a mesh
