Can the ObjectScale field be used in a block?
If so, is there any documentation on the steps required to use is in a block so that it can be linked to different views?
Hello - I am not sure what you are asking - are you referring to Detail scale in text?
Yes, the detail scale field. I would like to be able drop a block on a detail and (select the detail) have the scale displayed.
Any solution?
