Hi all,
I am trying find the weight centroid of a group of objects. I try to use the bounding box’s volumn centroid but it doesn’t seem right. I wonder if there is a GH component or plugin can help to calculate the weight centroid, assume those objects are same material and are the same density.
Thanks for any suggestion.
Hi Jack -
You can either script the Rhino VolumeCentroid
command or convert the object to meshes, join those, and use the Volume component on that:
Thanks wim! Could you also show me how to script the Rhino command VolumeCentroid?
How can I pass the breps to GhPython rather than manually pick it in Rhino?
Many thanks
Hi Jack -
You can use the VB script that David posted here:
MultipleVolumeProperties.gh (1.7 KB)
… but, I suppose, the easier way is to get the weighted average of the centroids:
Got it, thanks wim!
