Here is a collection of objects set to display a certain way in section - using Va’s section attributes tool in hidden mode.
If the objects are turned into a linked block, when it’s inserted its display doesn’t respect those settings. The file used as the linked block is attached below.
This is a big problem for me.
ON the left, the inserted block. On the right, the same objects imported. The Block display doesn’t respect it’s own object’s settings. Changing the section attribute settings of the block has no effect.
Vestibule.3dm (2.0 MB)
