Objects besides blocks are flickering
In my 3d model a I have almost everything in block, but the other geometries that are polysurfaces not as a block flicker a lot. The moment i turn them into blocks they stop flickering. Why does this happen? I/m importing here a video so you guys can check it out.
NOTES:
  1. It has never happened before.
  2. My CPU is Ryzen 7 6000 series and GPU is NVIDIA RTX 3070Ti
  3. My model file is quite complex,because these geometries are actually generated in grasshopper with wasp plugin, and then imported as blocks with the elefont plugin… but i never had a problem like this before, so i don’t think it’s an issue related to the complexity of the modelling.
That looks like a far-from-origin issue. Move your entire scene to around the world origin.
https://wiki.mcneel.com/rhino/farfromorigin
