@rajaa Any viewports that have been made to view a section (from section-tools) I am unable to go into that viewport and select objects.
Have you run across this yet?
Sections are placed in locked layers as a way to protect them from direct editing. The reason is that they are dynamic and update with model changes. Why do you need to select them?
Of course, if you know what you are doing, you can always unlock the section layer to select the objects.
I hope this helps.
Ok, seems like this is NOT a SectionTools problem. It seems any viewport that is from a view other than Plan makes it impossible to select geo. @Pascal or somebody else?
(thanks for the quick reply, @rajaa)
We’ll need to look at a 3dm file to try to find out what’s going on…
can you send me that upload link for sensitive material?
Hi - use https://www.rhino3d.com/upload
and make sure to put the url for this thread in the comments field.
