ObjectEnumeratorSettings ClassTypeFilter For Rhino.Geometry.TextEntity
Hi everyone,
I want to get objects that are TextEntity (excluding other annotations like linearDimension etc). Currently, there is only the ObjectType for Annotation.
I noticed that there are two different properties for ObjectEnumeratorSettings: ClassTypeFilter/ObjectTypeFilter. Can I use the ClassTypeFilter to do this?
Also, there’re three methods for GetObjectList:
  1. GetObjectList(Type)
  2. GetObjectList(ObjectEnumeratorSettings)
  3. GetObjectList(ObjectType)
Is there any example code for the first method? I don’t quite get what “Type” means here.
Much Appreciated!
Hi @vincentfs,
Keep in mind that TextEntity is type of geometry. If your looking for document objects, then you need to search for TextObject.
  var rh_objects = doc.Objects.GetObjectList(typeof(TextObject));
  foreach (var rh_obj in rh_objects)
    if (rh_obj is TextObject text_obj)
      RhinoApp.WriteLine(text_obj.TextGeometry.PlainText);
  return Result.Success;
– Dale
