Object which looks like it is filled with silica gel beads?
Greetings brilliant Rhino people!
I use Rhino/Grasshopper for 3D printable designs, but I just wanted to include a small “quality of life” object in it so that when I am screenshot it for instructions, objects look truer to life. I have a semi-transparent desiccant container which will be filled with silica beads (about 2.5mm dia orange spheres). I would like to create a “silica beads object” in the shape of the interior of the container which looks like it is filled with the beads. I tried creating the spheres individually, but this was way to graphically intensive and frankly overkill. I was thinking that if I can apply some kind of wallpaper to it that has an image of the beads it might be enough. I have no idea how to do this, however. Other options will be most welcome as well!
Thank you!
Hi @Jason_Englert,
Just for visual purposes? Or do you want/need a realistic count of how many beads you could fit in the container?
Please upload a .3dm of the container you wish to fill or a model that approximates it if you can share the exact design.
