Object visibility when copying in rendered view
When I copy an object in a rendered view the selected object is invisible once you select a point to copy from. Is there a way to change this so the source object stays visible (similar to an array)? It’s a problem when trying to copy the new object to an endpoint or any other snap on the source object.
Yeah… I see - I do not normally work in Rendered mode, but I see what you mean - you can turn on surface edges in the Display panel temporarily - you can do this in mid-command- for now. I’ll see if this can be tuned up.
https://mcneel.myjetbrains.com/youtrack/issue/RH-47827
Turning on surface edges is the workaround I’ve been using but it would be great to be able to work with edges off. Thanks for following up
