Object type cast error
I’ve encountered this issue. Running “join” command in Rhino works fine.
I have two surfaces and I want to join them to one polysurface.
As far as I understand, using the “block definition” component like this provides me with exploded geometry. Using “explode object” on “block instance” results in the same error.
@AndyPayne or @kike can you look at why a GH_Surface which stringifies itself to "Model Surface : {guid}" would fail automatic conversion?
Can you attach your Grasshopper definition and the Rhino file with the block definition so that I can take a look?
Attached
Example.3dm (6.4 MB)
Example.gh (10.2 KB)
Thank you. This has been fixed and will be available in the next service release of Rhino 8.5.
RH-80668 is fixed in Rhino 8 Service Release 5
