I am noticing that sometimes the little white dot which shows the location of the proposed snap point is not showing up. For example in the following for the second point for Distance. The snap is correct, the tooltip lights up but the on-screen dot isn’t shown. It is an important indicator that you are really snapping there and not somewhere else you don’t see.
I see it most often on the second pick of a two pick operation like Line or Distance. For a Polyline, it only shows up before the first pick (at a snap location). In V8, it is there for every snapped pick (before you click)
The difference is sometimes subtle, but it is there.
V8:
V9 Beta:
EDIT: No wait, that’s wrong - in the Beta, the white dot only shows up AFTER you make any pick, even the first one. In V8 it shows up before you pick at the proposed snap point, at all times. I changed the title of the post to reflect this.
