Object Snaps Don't Work on Worksession Geometry When Cut Plane Is Enabled
I’ve encountered another issue with VisualARQ’s Cut Plane.
When working with geometry from an attached Rhino file through Worksession, the geometry remains visible, but Object Snaps do not detect it.
This happens even with basic Rhino commands such as _Line, so it is not related to Gumball or a specific modeling command.
Steps to reproduce:
  1. Attach a Rhino file containing geometry through Worksession.
  2. Enable the VisualARQ Cut Plane in the active view.
  3. Try to snap to the visible geometry using End, Near, or other Object Snaps.
  4. Disable the Cut Plane and repeat the operation.
Result: Object Snaps work correctly when the Cut Plane is disabled.
Visible geometry should remain accessible to Object Snaps, regardless of whether the VisualARQ Cut Plane is enabled.
This makes it difficult to use referenced geometry as a modeling reference and disrupts the Worksession workflow.
Hi @badileanu I cannot reproduce this issue. Please share your file or tell me if you are doing it differently.
In my test below, the 4 walls, the door and the slab are in one file, and the circle and the slab inside it are in another file (the active one). I can drag the slab control point to any edge or geometry in the passive file:
snaps ws
Hi Francesc,
I finally managed to isolate the issue.
The problem is related to the Cut Plane height of the active level.
In my example, the Foundation level has the following settings:
  • Elevation: -1.00 m
  • Height: 1.00 m
  • Cut Plane: 0.50 m
With these settings, I cannot snap a VisualARQ slab control point to the referenced geometry in the Worksession.
However, if I increase the Cut Plane to 1.20 m, snapping works correctly.
The problem is that the Foundation level is only 1.00 m high, so increasing its Cut Plane to 1.20 m produces an incorrect plan representation.
I also noticed similar snapping behavior when creating VisualARQ multilayer walls.
I’ve attached a short video demonstrating the issue, along with the complete Worksession and referenced files, so you can reproduce it.
Osnap should not depend on extending the active level’s Cut Plane beyond its height.
Thanks!
R.
building-20261104.zip (11.4 MB)
