Object snaps and extrusions
Is there a way to snap to the mid/center point of an extrusion?
Should work - do you have an object where it doesn’t (that you can post here)? --Mitch
if you want the center of the volume then not, only on the perimeter surface or generally any surface or curve center. but you can use VolumeCentroid to get this point.
I assumed it was mid point of a side, but yes, for a volume center, you need _VolumeCentroid. --Mitch
