Object snap projection problem
If you turn off projection in Osnap and snap Osnap “center” of a circle in a position other than coordinate 0 on the front view, it should be selected as the center of the circle, but even if projection is turned off, the position of coordinate value 0 is selected.
did you check for updates ?
did you try to restart ? (computer and rhino)
which version of rhino are you using ?
run the command _systeminfo and post the result.
It was updated 2-3 days ago, so it must be the latest version.
Also, after rebooting the computer, the situation is the same.
cpu:ryzen 5900x
Rhino 7 SR26 2022-12-14 (Rhino 7, 7.26.22348.01001, Git hash:master @ 75d9704e78c487d6212f0a30cb275f20f791885c)
License type: 상업용, build 2022-12-14
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Ti (NVidia) Memory: 8GB, Driver date: 12-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.56
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-5-2022
Driver Version: 31.0.15.2756
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.26.22348.1001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\export_OBJ.rhp “export_OBJ” 7.26.22348.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.26.22348.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.26.22348.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.26.22348.1001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.26.22348.1001
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Named Position”
there is an option for this in Tools >. Options > Modeling Aids
Object Snaps : Project object snaps to CPlane in plan parallel views
OMG
very very Thank you
