Hi all. I’m making changes to objects in my objects properties panel but the object I am seeing in the panel is only visible in the plan view for some reason. No amount of ctrl, alt, shift or rmb seems to make a difference to the viewport. This makes it a bit tedious since I have to keep switching back and forth between my perspective view to see the changes in 3D, and then opening the OP panel again if I want to continue to adjust the object. Am I missing something obvious? Thanks in advance.
Hello @caila.anderson can you attach a screenshot of this issue? what changes are you doing?
Hi Francesc. I’m just making standard changes in the object properties for any number of doors/ windows. Even just seeing what the difference between a 4 pane glass door as opposed to a 2 pane glass door in elevation or perspective(instead of plan) in the object properties panel would help. I can see that it is possible when I watch tutorials, but I’m not sure why I can’t get out of plan in the object properties panel. I am able to shift the object around with my right mouse button but not rotate it. I can rotate it in 3D in the wizard…just not the object properties panel.
Screen shot attached.Thanks! Don’t know how I missed that.
