Object parameters
Is it possible to have a Parameter of one Object transmitted to another one ? For an example, you have a curve with a defined colour/linetype and want to go on adding further curves with the same parameter. Or is that just possible with layer settings and make the object preferences of the curve determined by the layer ?
Hi Luiz - you can use the MatchProperties to copy selected properties from one object to another.
