after the upload in SD the 3d object looks good.
When i uploaded a bit map for lighting some 3d objects are disappearing and if i change lighting options also it getting disappear.
i am getting it back if i change the respective parameters of the 3d object.
i tried clearing all the data tree and tried to maintain all the protocol.
model sd link
mathieu1
(Mathieu Huard)
August 1, 2023, 1:20pm
2
I could reproduce the issue and filed a bug for our team. I will let you know when we make progress about this topic.
mathieu1
(Mathieu Huard)
August 2, 2023, 2:08pm
3
@Uniceil_Prominance the model you linked above seems to be deleted. Is there another example of the platform of a model producing the same issue so we can use it for debugging?
Hello @mathieu1 ,
thank you for your reply, i resolved the problem .
after doing flip matrix it worked well in the SD viewer. (but without doing this process it seems working good in the grasshopper and rhino)
https://www.shapediver.com/app/m/wFpPsbZxEjhTZjHpAW6IW1QYkMC83U
