Hi, V5
Done this a few times, never had this before.
I have a greyscale image after choosing rendered in SetObjectDisplayMode, normally I get a colour one..
I revisit Metashape and redo the texture, save and export model as obj, same settings as previous one that worked ok, and all those before.
try again, and again its greyscale.
The jpg that acompanies the obj is mostly black with some colour imagery along the bottom.
All looks ok in Metashape.
whats going on ?
is it Rhino ?
I try for an .fbx, but Rhino says error importing.
Its opening as a black mesh, normally its white.
I try Rhino WIP9 and it imports as a white mesh.
SetObjectDisplayMode and rendered sees a colour, hooray. so export it as Rhino 5.
so why is this one importing as black ?
and its done this on the next model as well.
This is Rhino as V9 is ok.
so what has happened to V5 to suddenly start doing this ?
Hello anyone, V5
import obj is black, normally white, a displays grey.
however this one is black and after SetObjectDisplayMode displays colour,…phew !
why some black and some white before setObjectDisplayMode applied ?
I feared it was another greyscale one, but gremlins are asleep.
If you post a file and simple steps to repeat i will give it a go. Any new features /fixes will be in Rhino 8/9, nothing we can do with 5 going forward.
Not had this before,
V5 displays obj as a terrible mushy mess,
export the obj again, max setting 12 as before, cant see anything to better it, get same mess.
import first one into V8 and its ok.
The obj opened as black in V5 yet unlike recent issues displaying as greyscale, it did display colour when SetObjectDisplayMode was used. for a moment I thought all was good.
Need V5 until someone fixes the line quality issues and also ants on line for projections to mesh.
and I have been stuck with that projections problem for two years.
ITS UNACCEPTABLE.
I would like to move fwd ! Its bad and needs solving.
@Japhy
unable to upload is 22mb, now what ?
also do I need to upload the obj and its mtl and jpg as well as the .3dm file, that will also be big.
Hi, done.
One browses and finds out only one file is allowed,
then after gathering together the obj files and the 3dm and zipping, click upload and nothing happens.
needs a progress line.
You will get what appears to be a nice image, it is, look at the layer called:-
Agisoft Mshpe 2.3.2 B17 Nose Cheek Windows OBJ.obj
it has the V5 import on it. its awful.
the bottom layer (bottom of layer stack)
Agisoft Mshpe 2.3.2 B17 Nose Cheek Windows OBJ.obj imported via V8 then save as V5
has the V8 import on it, orient3pt to the first one, after much fiddling around.
as selecting mesh kills any chance of seeing what one is clicking on.
Its about time mesh selection didn’t go bright yellow mass.
perhaps V9 has solved this.
if it has and its also solved the ants on fishing line of projections to mesh, as well as line quality generally, then V9 here I come.
Method, draw circle around a ref point, project to mesh, select result, divide30, circleThroughPt, del previous bits, group circle to mesh,
repeat for other two points, then repeat this for the target object.
turn off meshes, then do Orient3pt using osnap Centre.
Phew !
I also need to send the greyscale issue file.
look out for that as well.
same as I did in V5, and unlike normally it shows colour, it shows greyscale,
I had 3 hoses, first worked fine, 2nd and 3rd went greyscale.
separate files.
Perhaps I could try for 2nd and 3rd into the 1st that was ok.
but if the problem is the obj and not Rhino, how become its ok in V8 ?
same obj export, all made on same day, all same v5 method,
baffled.
and it did it again for the file I sent you, so was repeatable.
I can try the 1st hose again, see if that behaves 2nd time around.
If it doesnt then something has broken since its first time.
and the panel is a mushy mess. and is ok in V8, so something ‘aint’ right at all.
So your V5 behaved itself, mine has gone naughty mode.
Hi @Japhy
need to see the detail on the object to pick 3 points, such as middle of a rivet, or a spider poop, etc.so yellow or green or whatever, doesnt allow viewing of the details.
it worked in V8, I am using V5 until V8 and V9 get fixed.
I have waited years for the fix,
why is the line quality and ants on line not being fixed ?
I want to be in V8 or V9 having paid for both now, but need the line quality and ants fixed, its prehistoric otherwise, even V4 was better.
Am I the only one working with meshes in Rhino ?
or wishing to see CAD quality lines befitting a serious prog as I get in V5 ?
Steve
Making things smooth across resolutions is a challenge. Forcing a one pixel aliasing rule creates issues as well. This thread which you are part of is good discussion on the topic.
I have just imported an obj into V5, the result of 3 hrs of painful camera on pole and up stepladder, 6 hrs drive, its very important, AND ITS A SOFT MESS.
So what has happened to Rhino V5 and what do I need to do to solve this ?
Can anyone test the uploads on V5 and see what it does, as it never did this before.
