Hi, I needed to export the control points, the knots and the polynomial degree of a geometry in order to read them in excel, therefore I exported my geometry using the*obj file.
What I would like to do now is to export the geometry applying a tolerance in order that some points close to each other can be recognized as the same point.
I mean, I have for example two points with coordinates:
0.245693 and 0.245690. What I would like to do is to set the precision to 0.24569 or to merge them in only one point since the two points arise due to a bad modelling. How can I do it?
Thanks a lot in advance.
Hello - you’ll need some scripting for this -
Hi, thank you for your reply.
Do you know if there’s something already existing for doing this using Rhino.Python? I am a beginner on Rhino.Python and unfortunately I have a very tight schedule to export this tricky geometry…
Hello - rereading your comments, are you looking to eliminate duplicate control points in the surface, or only in the exported information? Keep in mind that a surface cannot be recreated from this information by simply leaving out control points, if that is the goal.
I am trying to eliminate duplicate control points only in the exported information without doing it manually.
My geometry is made up of four patches i.e. 4 different surfaces each with its own control points.
These surfaces have in common the edges and even if I made my best to be accurate, some of the control points along the edges of two surfaces are slightly different and when I export them I can see they have different decimals.
What I would like to do is to export each single surface with the *obj function having for the edges the same control points instead of correcting them manually.
Hello - I see - if we can ‘fix’ the surfaces automatically in Rhino, then you use what ever export workflow you are currently using, would that do it?
Yes of course.
If the surfaces in Rhino would perfectly match, then I assume the export through *obj will have no “errors”.
Hello - if you use MatchSrf > Position, with match by closest points un-checked, does that get things close enough? And can’t you do this in excel? Round the numbers?
@robertoruggeri - see if this gets things close enough -
SrfTuneup.py (2.9 KB)
To use the Python script use RunPythonScript
, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
Hi @pascal thank you for your reply.
Unfortunately both of the ways you’re proposing are not working.
In particular the Python script gives me this error after I select my surfaces:
Thank you in advance for your help.
Hello - please post, or send me the surfaces.
Hello - is this the level of discrepancy you are looking at cleaning up?
ON_Point: (-12.037037037037038, 9.9585608853592115e-11, 2.370370370370372)
ON_Point: (-12.037037037037042, 9.9585545408330765e-11, 2.3703703703703729)
My script did have a mistake in it, but nevertheless, removing that noise at the end is probably much easier and more reliable in Excel.
