While rotating simple model in shaded mode the screen is jerking and flickering. It has worse performance than my 8 years old AMD card (which suppose to be not suited very well for Rhino, so wtf?)
I don’t know what to do anymore. Need an advise from someone who really understands these cards. So many boxes to tick and things to adjust but they seems only worsen performance.
problem applies for all versions of Rhino.
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 63Gb)
Primary display: Intel(R) Arc™ Pro Graphics (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA RTX 2000 Ada Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.83
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-14-2025
Driver Version: 32.0.15.7283
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\piotr\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
Having Intel Arc Pro iGPU in such a device… I would hazard a guess that you are running an Intel Meteor Lake laptop (165H).
You may want to check what something like HWinfo is showing when you rotate the viewport, as Meteor Lake was built for efficient performance. Not extreme as Lunar Lake, but it may yet have some reasonably extreme power throttling behavior.
It may be worth conducting your rotations and check what both HWinfo and GPU-Z have to say about what is happening. If there is a power profile problem, then that would seem reasonably obvious.
The Intel Arc drivers are very old, and they have done a huge number of updates since Arc release. It’s definitely worth updating those drivers as well.
My guess would be the Hybrid Graphics. I had problems with two laptops like this. The lower spec one was being used for supposed ‘low end’ tasks while the high spec one was meant to cut in upon demand. Caused many issues including very poor performance.
Solution was to disable the low spec one completely, in bios, if my memory serves me correctly.
We have been told for ten years+ that the developers can not do anything to affect what GPU Windows prefers to use on Rhino (But we users can affect this through drivers and power settings)
So I thought, since AI has developed some insight during the last two years, that I should check with it, and it states that this is now possible on windows 11, I don’t know if this is right or not, but it might be worth a shot @wim
Apparently these are driver-level hooks, and the GPU drivers (NVIDIA or AMD) simply check for the presence of these exports when the app starts. A f the system doesn’t have an NVIDIA or AMD GPU, the exports are just ignored.
For C++ :
And it seems to be an OpenGL option too. Even though you don’t need to check for vendor presence, you can log or show which GPU is actually being used via OpenGL:
Being advised by Chat GPT I have swapped my workflow (I had Rhino on primary and Gh on secondary) and it made the difference (!), meaning it is the Intel card giving me troubles. I have to kill it through BIOS
