I have an NVIDIA card and I’ve installed the denoiser through the package manager on Rhino 7. I cannot get it to show up in the post effects tab or in the render window.
Ironically, if I install the AMD denoiser using the exact same process, it appears everywhere. I cant use it, of course, as I have “no supporting devices”.
Please let me know if this is a bug or if I’m missing something in order to get it to show up.
Thank you very much!
I have the same problem with the Intel one. I can install but it won’t show up. Only the AMD denoiser shows up as a post effect… very weird. I have the latest Nvidia drivers I have installed and reinstalled all 3 denoisers several times and I have reinstalled Rhino 7. On settings, I have cycles set to CUDA. I can’t think of anything else. I have asked my work colleagues to try. They have the exact same hardware as me and it does work for them. I must have some setting wrong. any other ideas?
Thanks for the quick response, Nathan!
Have you looked under Tools > Options > Plug-ins to see whether the denoiser plug-ins are loaded? If not try right-clicking each and select Load plug-in. Please pay attention to the command-line output while doing so. Any error message that appears there would be good to get a copy of in here.
Also check if a file called RhinoDotNetCrash.txt is created on your desktop around the time of trying to load the plug-ins. If there is please attach in a reply.
Maybe try figure out the differences in installed software? Maybe there is some antivirus blocking the plug-ins from running?
Yesterday I figured out through crashdumps that a user was using gaming overlays (i.e. Overwolf and the likes, also Discord) that made Rhino completely crash - maybe you have any utility software running that may interfere. Please check and disable anything you don’t need for Rhino work and see if that improves at all.
I uninstalled Discord - that is something I have that my colleagues don’t. Uninstalled the plugins. Reinstalled the plugins. They don’t event how up in the plugins list, but they do show up in the package manager as installed.
there is no RhinoDotNetCrash.txt. Rhino never crashes on me though, it’s just that the denoisers don’t appear to be anywhere.
Thanks again
thanks again, everyone.
I have the exact same setting as John’s posted above.
It seems like the plugins aren’t in that address you said, Andrew. Does that tell you anything?
I am certain the plugins are installed through the package manager
I found the folders in there! Deleted. Opened Rhino, installed Nvidia denoiser from the package manager. Closed out. Restarted Rhino and it’s there, but not showing up again…
Thanks David! Still no luck…
