Nurb to mesh in Python
Dear All,
I am new in Rhino (Mac) and I try to generate a mesh based on a Surface or Polysurface from a Python script.
I found the function MeshToNurb I was wondering if there is a way to generate a mesh from a nurb as in the menu Mesh->From NURBS objects.
Is it somewhere out there and I miss it, if not is it an incoming feature?
Thank you very much
I believe what you need is simply the command ‘mesh’…
If you are looking for a method instead of a Rhino command, then use the Mesh.CreateFromBrep.
Dear Djordje,
It worked fine, thank you.
Adrien
