Hi everyone,
as of a private discussion with @dale and @curtisw I would like to post the solution we came up with to present a DBNull
or null
value in a NumericUpDownWithUnitParsing
. When using the NumericUpDownWithUnitParsing
the default value is set to ‘0’ even thougt you want to display no value (DBNull
or null
). @dale and @curtisw suggested to use:
NumericUpDownWithUnitParsing.IsAlternateTextVisible
NumericUpDownWithUnitParsing.AlternateText
as a work arround. Here is a code snippet:
NumericUpDownWithUnitParsing stepper = new NumericUpDownWithUnitParsing
BackgroundColor = Colors.Transparent,
Increment = 1.0,
MaximumDecimalPlaces = 100,
TextAlignment = TextAlignment.Right,
Tag = false,
ShowStepper = false,
AlternateText = "<null>",
AlternateTextColor = Colors.DimGray,
ShowBorder = false,
object value = null;
if (tuple.Item2 != null && tuple.Item2 != DBNull.Value && !string.IsNullOrEmpty(tuple.Item2.ToString()))
double d = Convert.ToDouble(tuple.Item2);
stepper.Value = d;
value = d;
stepper.IsAlternateTextVisible = Equals(value, null) || value is DBNull;
stepper.ValueChanged += new EventHandler<EventArgs>(this.OnValueChanged);
stepper.KeyUp += new EventHandler<KeyEventArgs>(this.OnKeyUp);
The events handle some special key events like Escape
, Delete
, Backspace
, D0
and Keypad0
. A short gif animation of the final UI behaviour.
Many thanks to @dale and @curtisw.
Kindest
Christian
