Hi all,
Does anyone know what causes this strange behaviour of the Number Slider? It seems to be using , as decimal seperator instead of . .
Ex. writing 0.01..1.00 will return a slider ranging from 1,00 to 100,00 instead of the expected 0.01 to 1.00.
Best reagrds,
Christian
kike
(Kike Garcia)
2
Hi @Christian17
What version of RiR are you using?
Something similar was fixed on v1.33.
Hi @kike ,
I’m using v1.32 - I’ll update and let you know if it will fix the issue. Thanks!
I had the same issue. This probably falls under workaround, but this Windows region setting “fixed” it:
