I have a data structure of planes that looks like {A;B;i}
where i
is equal to 14. I separate the planes out using Sift
so I can do some alignment/orientation to them, but when I do so the <null>
items in the sifted
branches become Null Planes
Once I’m done working with the planes I’d like to combine them back into their original data structure. I tried using the Combine
component, but found that the Null Plane
type that is created doesn’t work the same as <null>
when using Combine
I have a work around where I use Clean Tree
to remove the Null Plane
values from each list and then use Merge
to recreate the structure I had originally, but this relies on me linking the separate branches in the correct order.
I’m not a wiz when it comes to data structure management, but this project is really reliant on the structure remaining intact while moving through the script; is there a more elegant solution than cleaning and merging?
Cheers,
Luke
