Kunsthaus study 11.30.gh (76.9 KB)
Hi Everyone,
I am trying to build up a 3d model following the example of the Kunsthaus in Graz.
I find very complicated to reconstruct the nozzles…
every help is highly appreciated ^^
Thanks!
Hi Everyone,
Thanks!
I’d start with BlendSrf. Create cylindrical surfaces which wrap around the tips of the nozzles, and cut circular or elliptical holes in your base surface. Then blend between those trims.
You could also try sub-d surfaces in Rhino7, but they weren’t available when the Kunsthaus was made so they used a different approach back then.
Looks a modeling with other software or tsplines
I think it has been modeled with Catia. I am trying to rebuild the logic using GH. But it’s a little complicated.
Looks there are different parts ; check the link and you can try something like that: one shape from hexagon and the second from circle
Hey,
Here’s a way to achieve the basic shape as a neat and highly customisable mesh, which makes your file much more efficient and quick to work with. The oculi are produced by point attractors. You may introduce as many as you see fit.
I’ve included a custom Python component of mine that handles the mesh lofts. For now they are simple straight extrusions, but you can produce pretty much any shape by just feeding the right, ordered section curves (polylines) to this custom component.
Kunsthaus study 11.30 v2.gh (45.5 KB)
That’s way closer to the desired result!
Thank you so much!
Graz, Germany?
I don’t think you should do this in Grasshopper at all. It is much simpler to create the blendings manually as kind of postprocessing unless you plan to create more then 14, as you see at the Kunsthaus. The reason why you have difficulties is because in Grasshopper you don’t have no good tools for building blend/transition surfaces. I mean you can prepare as much as you can in GH and do the rest manually.
Edit: unless you go for surface data instead of mesh data of course
You are right, I still haven’t find a good method to deal with the blending/transition surfaces.
Thanks for your advice.
If you are simply looking for smoother transitions, you can simply subdivide the mesh from my above example with the Catmull-Clark component from Weaverbird.
Thanks for your help all other’s contributions!
Here’s an example on how to model the individual oculi more cleanly:
I would model the windows as separate geometries. You can start by extracting the naked edge of the opening as a base and continue from there.
Thanks! ^^
Oops, I forgot to append the file!
oculus_modelling_example.gh (21.6 KB)
This should also give you an idea on how to model the big building openings more cleanly. For this method to work, you need to keep the point count of your polylines constant.
Hi there. I am trying to model Kistefos museum, however I am new to Rhino, and even though I am trying to do it for a week now, is not working. I have an assignemt to do for Thursday and I really need help. What would you suggest for the pannels of the building and the detailed rounds that are above?
Welcome Achim,
You could have started a new discussion for this topic, since it isn’t really related to this one.
The Kistefos museum is a pretty straightforward design. Here’s one way to achieve the base form.
kistefos_museum_01.gh (18.9 KB)
i’m sorry, I meant kunsthaus in graz*
