Does the Rhino 9 USD export have the ability to contain breps? If not are there any plans to update it so that it can? Has anything been tested internally?
I’m thinking of trying to vibe code an exporter to see what happens, from what I’ve seen Claude can write USD containers that have breps in and Blender can import USD with breps in.
FWIW I have a USD brep modeller that works in Blender and SolidCraft is using the nvidia’s kernel that is in USD Brep but I don’t think it can necessarily export a USD with breps inside it yet. I don’t know of any implementation of this yet.
Rhino 9’s USD export doesn’t write breps. Polysurfaces, surfaces, extrusions and SubD objects are converted to meshes when exported, using the export’s mesh settings. Curves are the exception: they’re written as native USD NURBS curves (NurbsCurves prims). Block instances are written as instances.
So if you open a Rhino 9 USD export in another app, solids and surfaces will come in as polygon meshes, and curves will stay NURBS.
Do you have an application that reads Breps from USD files?
