Notilus Steeler now supports imperial units
Notilus Steeler, our Rhino plugin for ship and yacht structure, now works in imperial units. Start a project in a Rhino document set to inches and Steeler follows it everywhere: windows, library lists, 2D output and reports work in inches, with main dimensions in feet.
The document decides
There is no separate switch to remember. Steeler reads the unit system of the Rhino document: an inch document works in inches, and millimetre documents stay in millimetres exactly as before. The Settings window shows which system is active.
Every window in inches
A project takes its length, beam and draught in feet, and the midship and frame table in inches. The frame, stiffener, bracket, cutout, lightening hole and bulkhead windows take their values in inches, and the project, profile library, cutout and lightening hole windows also accept fractions such as 5/16 or 3+1/8.
Web frames are generated from spacings and web depths in inches, and the preview follows as you type:
Web frames generated at 48 in spacing
One library for both
Plate thicknesses and profiles are kept once, in millimetres, and shown in inches in an inch document: the 3/8" plate reads 0.375 and the 1/2" x 4" flat bar FB-0.5x4. What you pick maps back to the exact library entry, so part numbers and weights stay right. Profiles you have given your own names (aliases) are shown as you named them.
Nest sheets and the part list report follow the document as well: plate size and thickness in inches, cutting and marking lengths in feet, plate areas in ft² and centre of gravity in feet. Weights stay in kg.
Units are locked once parts exist
The part geometry Steeler keeps in the project database belongs to the unit system it was created in. When the units of a document that already holds Steeler parts are changed, Steeler reverts the change and explains why.
Status
Imperial support is part of the current release, for Rhino 7 and Rhino 8 on Windows.
We would like to hear from yards and designers working in imperial units: which profile series (flat bars, angles, bulb flats) you need in the library, and whether you work in decimal inches or feet and inches.
Download
Notilus Steeler, together with our other Rhino plugins, is available at
LinkedIn: Notilus Software | LinkedIn
