Notilus Mechs Update: Gears That Mesh and Move (Spur, Rack, Bevel, Ring)
Earlier this month’s update added slide joints, IK drag and a motion timeline to Notilus Mechs. This one adds gears: you draw them, place them in mesh, link them, and the mechanism solver turns them together.
A gear train with a rack, a spur train, a bevel pair and a ring gear, driven by one NmAnimate step
The model above is one gear train: a rack on a slide joint, a spur train, a bevel pair and a ring gear. One NmAnimate step turns the first shaft 360°, and every other gear follows through its gear constraint.
NmGears: one window for every gear
NmGears opens a window with four tabs: Spur, Rack, Bevel and Ring. You set the teeth, module, pressure angle, helix angle (or herringbone), profile shift, backlash, thickness, bore and color, and a 2D preview of the tooth profile updates as you type. The window also warns you about problems before you place anything, for example undercut teeth on a small pinion, with the fix (a positive profile shift).
The NmGears window: drawing a 20-tooth gear, then placing a 12-tooth gear in mesh with it
  • Spur and helical gears: involute flanks generated by the rack cutter, with a trochoidal root and undercut where the tooth count calls for it. Helical and herringbone gears are real solids, not surfaces.
  • Racks: standard basic rack profile, straight or helical.
  • Bevel gears: you set the teeth of both gears and the shaft angle, and the pair is built to mesh.
  • Ring gears: internal teeth. The tip is trimmed so the pinion’s teeth clear it through a full turn.
Mesh with: place a gear already in mesh
Pick an existing gear, rack or ring under Mesh with and the new gear is placed at the right center distance and with its teeth in the gaps. You only choose where around the mate it sits. Planets inside a ring snap to the angles where they mesh with both the sun and the ring.
Link gears: the gear constraint
Link gears adds a gear constraint between two placed gears (or a gear and a rack or ring). The ratio comes from the tooth counts and the command line tells you what you get, e.g. 'Gear z12 m2' turns 1.6667× as fast as 'Gear z20 m2', in the opposite direction. It works for:
  • gear to gear (external) and gear to ring (internal)
  • gear to rack: turning the gear slides the rack, and sliding the rack turns the gear
  • bevel pairs at any shaft angle
  • planetary sets, with the carrier as a part
Gear constraints are solved together with the other joints, so live drag, IK drag and NmAnimate all drive them. They are saved in the 3dm. Collision check leaves linked gears out, since their teeth are meant to be close.
Link gears, then turning one gear with live drag while its mate follows
Turn one gear with live drag and its mate follows. In our tests, meshing pairs keep the backlash you set through a full turn, with no overlap.
From an empty file to a running pair
The walk-through in the video: draw a 20-tooth gear, place a 12-tooth gear meshing with it, put both on the pins with Concentricity, link them, and animate one turn.
A 20/12 gear pair on two pins, driven by NmAnimate
The same train driven by hand instead of NmAnimate:
Live drag on the gear train: the rack slides and every gear turns with it
New command
NmGears. It is the only gear command you need to type; drawing, meshing and linking all start from its window.
Status, and what we would like to hear
Rhino 7 and Rhino 8, Windows.
  1. Helical/spiral bevel gears and worm gears are the next candidates. If another gear type would matter more for your work, tell us.
  2. Files that break it. We’d especially like to see gear trains that jam, ratios that come out wrong and planetary sets that won’t assemble.
Download
Notilus Mechs, along with our other Rhino plugins, can be downloaded from
LinkedIn: Notilus Software | LinkedIn
Can a gear be built (or modified after building) with a radial profile on each side and still work in the animation? How about holes of arbitrary shape through the gear? eg: thick hub and tooth edge with thin web with lightening holes.
