Notification tabs proliferating
Just a minor irritation: I get more and more spurious Notification tabs (bells) appearing in my tabbed panels. Up to seven just now. Only one has any text. I can untick Notifications in the panel options and the legitimate one disappears but the rest remain and cannot be got rid of (and the next time I look at options, notifications is ticked again).
Appears to be benign, but nice if it could be fixed some time. Has been present through all Rhino 6 releases up to and including 6.6.18156.11421, 05/06/2018.
Thanks
ResetMessageBoxes command resets all of the “Don’t ask me again…” dialog check boxes to “No.”
Hi Andrew,
There aren’t any dialogues. The tab labels are there, but there is absolutely nothing on the tabs - as here:
. The first notification says Licence obtained, the rest are like the one shown.
And, sadly, the empty tabs are unaffected by ResetMessageBoxes.
Hi Jeremy - can you run Help > System information… and paste the results here? thanks,
Rhino 6 SR6 2018-6-5 (Rhino 6, 6.6.18156.11421, Git hash:master @ 56799860400d22a41148fb77e55b1181e81ebe7b)
Licence type: Commercial, build 2018-06-05
License details: Cloud Zoo. In use by: Jeremy Swift ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: SB-JEREMY
GeForce GPU/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 388.08)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-19-2017
Driver Version: 23.21.13.8808
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.6.18156.11421
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp “Rhino Render”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.6.18156.11421
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.3.1.650\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.6.18156.11421
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.6.18156.11421
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2018.1.9.1166\SectionTools.rhp “SectionTools”
Hello - ok, thanks - nothing leaps out at me - there is an old item on our pile that was closed long ago because this or a similar problem showed up and then apparently went away - I am reopening it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-40091
FWIW if trying to reproduce this, I don’t have administrator rights on my user account.
Jeremy
Hi Jeremy - got that, thanks. Added to the YT item.
Hi Pascal,
As the elements of the tabbed panels window are user-specific and persistent, where does Rhino 6 store the user’s choice of panels?
Regards
Jeremy
Hi Jeremy,
Don’t know if this is still relevant, but here is a workaround for the proliferating tabs until it gets resolved.
Grab the notification by the tab at the top and drag it into the main window. The tab becomes a separate panel that you can simply exit out of. This seems to work for me and every so often I just clean out a half dozen or so!:sunglasses:
V/R
Jesse
Thanks for that, Jesse. After losing my settings, my extra tabs disappeared and I’m still down to a single notification tab but I’ll keep your workaround in mind lest they multiply again. It’s a clever solution.
Jeremy
I also have this problem for quite sometime now and the workaround mentioned by Jesse works but its kind of annoying always have to do this way.
Notification1
Notification2
Notification3
same here, any progress on this issue?
ResetMessageBoxes doesn’t remove them…
I have this same exact problem. On my personal copy of R6 at home there are 7 empty notification tabs, the R6 copy I use at work has 2 empty notification tabs, and my coworker right behind me has 9 empty notification tabs in his copy of R6.
Hi Derek,
I haven’t seen this on my machine for a while (I hope I don’t regret saying that :roll_eyes: ). I’m running Rhino 6.12.
Regards
Jeremy
Hi Derek - can you please run SystemInfo in Rhino and post the result?
This is from my personal copy on my laptop:
Rhino 6 SR12 2019-1-29 (Rhino 6, 6.12.19029.6381, Git hash:master @ ae9d7fba5fda0b43002dc44a34e059a9a382db04)
License type: Commercial, build 2019-01-29
License details: Cloud Zoo. In use by: Derek Heming ()
Machine name: MSI
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 1-30-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 418.81
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 1-30-2019
Driver Version: 25.21.14.1881
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.12.19029.6381
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.12.19029.6381
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.12.19029.6381
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.12.19029.6381
Hello - thanks - I’m investigating - this was a problem earlier in V6 and was fixed, but apparently not quite - @aj1 - do you have an idea? Looks like the message is about Accounts…
We’ve known about this issue for a long time but was never out there in public enough to take priority. I don’t believe this has anything to do with the actual notifications but with the way that Rhino renders the notifications panel.
Also here is the SystemInfo from my coworker’s computer:
Rhino 6 SR13 2019-2-4 (Rhino 6, 6.13.19035.17431, Git hash:master @ 4db2f1dae993e341aa4a75f0ae541637efc4b3c0)
License type: Commercial, build 2019-02-04
License details: Cloud Zoo. In use by: james piazza ()
Windows 7 SP1 (Physical RAM: 32Gb)
Machine name: JIM-PC
Primary display and OpenGL: NVIDIA GeForce GTX 1060 3GB (NVidia) Memory: 3GB, Driver date: 5-22-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 397.93
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 5-22-2018
Driver Version: 24.21.13.9793
Total Video Memory: 3 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.13.19035.17431
C:\Program Files\Rhino 6\Plug-ins\RhinoCAM 2019 for R6\RhinoCAM 2019 For Rhino6.0.rhp “RhinoCAM 2019 - The cutting edge CAM plug-in for Rhino 6.0 from MecSoft Corporation”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.13.19035.17431
C:\Users\JIM\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.3.1.650\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCAM 2019 for R6\RhinoArt1FileExporter For Rhino6.0.rhp “RhinoArt1FileExporter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.13.19035.17431
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.13.19035.17431
