After Deleting the side building it is not updating the building.
Japhy
(Japhy)
April 2, 2026, 11:30am
2
Hi Snehal Raut,
We’re going to need additional information to be able to help. Can you provide your Revit and Rhino versions and a small example file showing the issue? Thanks.
4. Isolating the issue and posting files
Revit projects are rarely small & the issues are rarely simple. Its understandable that support files aren’t always readily uploadable, for size or for privacy concerns.
That said, here are some recommendations:
Isolating the question to a new Revit file with the Revit Version in the File Name, then purge the Revit file several times to reduce size.
List your GH plugins needed to review the question, if possible remove all gh plugin components no…
