Not getting how to modify layer attributes
I must be doing something stupid here:
import scriptcontext as sc
def CopyLayerAttribs(source_layer,target_layer):
    layers=sc.doc.Layers
    si=layers.Find(source_layer,True)
    ti=layers.Find(target_layer,True)
    layers[ti].Color=layers[si].Color
    layers[ti].CommitChanges()
layerA="Layer 01"
layerB="Layer 02"
CopyLayerAttribs(layerA,layerB)
I also tried with layers.Modify() but i couldn’t get that to work either… I’m sure I missed something simple…
Thx, --Mitch
Hi Mitch,
Modify() is definitively the way to do it.
Other than that I noticed that it is always better to assign the specific object to a variable, and then change it’s Geometry, Attributes - Color, and so on. In this case that would be “Layer 01” and “Layer 02”.
I guess @stevebaer or @dale might tell us more about this.
    si=sc.doc.Layers.Find(source_layer,True)
    ti=sc.doc.Layers.Find(target_layer,True)
    sLay = sc.doc.Layers[si]
    tLay = sc.doc.Layers[ti]
    tLay.Color=sLay.Color
    sc.doc.Layers.Modify(tLay, tLay.LayerIndex, False)
layerA="Layer 01"
layerB="Layer 02"
Yep, that seems to be the key… I’m going to assume that you can’t modify the layer’s attributes in place, that you need to create a new object, change its attributes and then transfer those to the existing layer in the table. I had just assumed that CommitChanges() would let one do that directly for an individual layer in the table…
Anyway, thanks for testing djordje…!
–Mitch
Assigning to a variable is the correct way to go about it. I’ll probably be able to fix this in V6, but I can’t really change this for V5.
OK, thanks Steve! --Mitch
