Noob question
Let’s say I have a 10 x 10 grid of points. Now I want to manually specify the path of a point to highlight it. Let’s say the path is {0;0;2}[3]. I have already entered the path in a panel. What component can I connect the panel to to highlight the corresponding point?
I am a beginner who is just playing around to see if I can determine which item a path is referring to.
Tree branch + List item components should do the job.
Thank you! Yes, indeed, Tree Branch does the job.
The only problem still remaining is that the whole branch is highlighted, but not the list item. I am using the syntax {0;0;2}(3). So, the 4th item in the 3rd branch should highlight, but instead, the whole 3rd branch highlights.
I am not sure if Tree Item is native. Here are 2 ways you can do it, though.
